I just took ownership of a 1967 Evinrude 18hp Fastwin. It has not been used for several years. I read tons of stuff here about how to do some routine maintenance prior to starting the motor e.g. check and replaced the impeller, replace gearcase oil, change plugs, check coils, etc. After doing these things I put the engine lower unit into a barrel of water and fired it up. It started on the third pull, idled nicely, revved fine, shifted fine. I let it run about a minute and then realized that no water was coming out of the two holes on the back of the lower unit casing. My question...should water come out of these two holes (tell tale) or is there no tell tale on this particular motor? Thanks.
