bob johnson
- Feb 25, 2009
- 4,304
the motor harness running up to the center console has a few loose wires.
I am pretty sure they go to individual guages.
I have figured the white,w/brown stripe is the TRIM sender wire
there are 2 blacks, and 2 purples and ONE GRAY left over
From trying to look over the wiring diagrams in the few books I have( some with out color or lettering for colors)
I think I have traced the gray to the rectifier/regulator
would that make the loose gray lead my sender for a VOLT meter?
the purples are for what???
powering the guages with ignitions supplied power?
the lights seem to have their own power source
and I supposed to wire the lighting for the individual guages in with the Navigation lights?
Thought i saw that some where....so the lights come on when it is dark enough to need NAV lights
what happens when i have more than two guages i want to power up?
just splice into the purples???
same goes for the blacks?
can I just run black wires from my gauges right to my Negative BUSS BAR under my console??
or do i have to tie them into these two black wires coming in from the harness??
which is the right way to do it??
thanks
the gauges i will run are
TACH( there is a big 8 pin plug on the harness for the TACH)
trim guage
volts
water pressure
water temps
and a height gauge for my hydraulic jack plate, but I am all set with that
I just checked and it seems the temp sender wire is TAN, but it runs into the tack plug....can I splice into that and use it for the temp GUAGE I am installing?
hate this witing stuff
next up after this is the boats harness. I just bought....but need to plug in extra wires, because i have more accessories and I have them in different places that the boat MFG did
thanks
bob
thanks
trim guage
volts
water pressure
water temps
thanks
bob
