Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
What are the symptoms of a bad coil?
  • What are the symptoms of a bad coil?
    How will my 70hp Johnson run if I have one bad coil?
    Re: What are the symptoms of a bad coil?
    A bad coil can go in and out and cause power surges when you get spark on the dead cylinder. It can just lack power totally because one cylinder is dead from no spark. OR, it can run fine, then when the motor warms up and thermal expansion causes you coil to go out, then lose power.
    I would think that the simple way to find out would be to check spark, then switch coils and see if the spark failure followed the coil. If you have intermittent spark because the coil goes in and out, it's harder to diagnose. Lots of times, you can pull the plugs and see which one is dirty/oily to find out which one isn't getting good spark.
    Good luck,
    JBJ
    Not a certified mechanic but I have at least 2 shade trees in my yard and my wife always says I'm certifiable. So remember that when you follow my advice
    • #3
      I think i have a problem with my coils on my 175hp mercury. it starts first try cold but once it gets warm it wont start for anything. i know its been a long time since this thread has been posted on but if you could, could you give me a update on if you got it to work and what you did? thanks.d
      • #4
        Check out the Mercury section of iBoats:
        http://forums.iboats.com/forumdisplay.php?f=25
        You can check the coils by putting a timing light on the plug wires while running the engine in the same situation you normally experience the problem. Good ones fire steadily and bad ones miss or don't fire at all.
        • #5
          Very old thread to go at again. Suggest you start a new thread stating the issue. Mod's will likely close this one.
          sigpicMarada 2100 Executive Series, 5 Litre V8 with Mercruiser Alpha 1 outdrive. 2007 K-Z Spree 260 RBH, all = a whole lot of family fun !!!!
