Hey all,
I can give the model # when i get home if need be, but here's my problem...
I'm replacing the water pump. i pulled the lower unit and the drive shaft stayed in the head and the shift shaft came down with the lower unit. i've tried to pull down on the drive shaft, but it doesn't come down. The Secor(sp) manual says it should just pull down with the lower unit after removing 3 bolts and shifting into forward while turning the prop.
I think i need the drive shaft down b/c i have to insert a key for the impeller on the notch on the shaft.
Any ideas on how to get the drive shaft down? HELP
