Edfromwisconsin
- Jul 3, 2008
- 11
Over the past year, when I can, I have been working on a 1950 10 hp Johnson QD-11 that has not been used for many years, with a lot of help from the folks out in this web site. I did all annual maintenance items for the engine, replaced leaky seals on the gas can so it holds pressure. I had it running rough at start speed for about 20 minutes. Shut it off to move to a boat from the test can. Could not get it started again. I have used an in line spark plug testor and have spark on both cylinders, so electrical looks OK.
When I hook up the gas can hose to the motor, with only one or two pumps on the plunger on the can, gas floods the carburator to the point it spills out the carb and onto the floor. This continues until the pressure in the gas can is dissipated. Basically, the carb floods out and the engine won't start when ever I hook up the gas can.
Need some ideas on what's happening and what I need to do to fix the problem
Thanks
Ed
Thanks
Ed
