Re: johnson 225 venom power pack
Slight problem with your analysis....your switch is always open? That failure mode cannot cause the loss of three cyls. If the switch was always CLOSED, then your symptoms would follow the failure mode. So, double check your thinking....that switch would have to be always CLOSED to cause three stbd cyls to shut down. Also, note the age of this posting/thread. The sysops don't like to resurrect the old ones for some reason.
