I have a 1989 175 hp johnson. I just replaced the water pump, thermostats a coil, all spark plugs and wires, new battery and replaced the fuel/VRO pump last year. Engine is idling fine but when i bring her up to speed i am getting an alarm. Water pump is working fine so its not overheating.
One thing i have noticed is at idle the Tach is working but as i bring her up it drops to zero, so around maybe 2000 rpms the alarm goes off. I have heard that it could be the rectifier regulator? But if it is, would i get an alarm? if not that any other suggestion??? Thanks
