Re: Evinrude Voltage regulator
I have spent countless hours trying to find a solid state replacement for those. Had several leads, but they all dead-ended. The only possibility that I know of is for some early Harley Davidson motorcycles. Be careful, you need a 10 amp regulator. The higher amp ones will burn up your generator.
Safest and easiest way is just get the right one from an Evinrude dealer. They are about $100.
