Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
1 of 2 < >
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 1 PM MST on 12/16/2017. The estimated amount of downtime is 3 hours. Thanks for being a part of the iBoats community!
2 of 2 < >
See more
See less
Spring tune up cost????
  • Spring tune up cost????
    I'm taking my 84' 90 horse Evinrude to the dealer for a complete checkup and impeller replacement, ran fine last summer, but I bought it last year and don't know much about how it was taking care of before I got it, so a good going over is in order. What should I expect to pay for this service? thanks
    Re: Spring tune up cost????
    I paid $360 plus $100 for a choke solenoid..
    1987 Boston Whaler "Outrageous 18"
    1989 Johnson 120 V4 VRO
    • #3
      heheh, needless to say they didn't rebuild the carbs?
      From gathering prices that people pay, I'd say you could drop a grand easy if they rebuild carbs at $100 per carb, water pump, oil change , plugs etc.
      I hired one those marine mechanics you see on craigslist who work independantly, the goin rate is around $65 hr.
      He came out and we went through the engine top to bottom, I knew nothing about outboards but he showed me everything he did. He spent almost 5 hrs but only charged $180 plus parts. We test ran the engine, seafoamed it too.
      He also showed me how to rebuild a carb, I later got 6 carb kits and did it.
      If I had to pay a marina I couldn't own a boat.
      Thats why we're here.
      sigpic
      See FAQ Files.
      http://forums.iboats.com/showthread.php?t=299680
      Get the genuine factory service manual.
      www.outboardbooks.com
      • #4
        that new it will have electronic ignition so nothing to do there. Change of plugs. I am not a fan of rebuilding carbs unless they need it so if it is running good leave them alone. change the impeller if you don't know it's been done in the last two years. change lu lube and grease fittings. Basically look things over for bad fuel lines ect. I don't hire shops to do it as a rule so I cannot tell you.
        • #5
          1984, if the fuel lines have not been changed to alcohol resistant, that is a "must" that needs to be done.
          FLORIDA GATORS
          TEBOW Country
          Please, NO PM's (Private Messages) regarding boat/engine problems. they will not be answered.
          That is what these forums are for. Post your questions, in the appropriate Forum.
