First off, I'm not positive of the year of this unit. It's a model 100ESL72R. Is it a 1972, and is it electric shift?
This is not mounted on a boat and has been stored for 5-6 years, and I'm having trouble figuring out the wiring from the harness that leads to the controls. I have a Clymers shop manual and think I have figured out most of the wiring, except one larger gauge red wire.
Here's what there is and what I have found on Clymers.
Red- Unknown (this is a larger gauge wire than the rest)
green - shift selector
blue - shift selector
purple/green -shift selector
black - control housing ground
White - ignition (S)
purple/white - ignition (battery)
purple - ignition (ignition)
tan - horn (for temp switch)
grey - tach lead
Does this sound right? What is the larger red wire for?
Before mounting this on a boat I just want to hear it run. Can I just hook up the 3 ignition wires. I do have the ignition switch as well as the shift control.
Thanks in advance for any help.
grey - tach lead
