Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
1 of 2 < >
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 10 AM MST on 12/16/2017. The estimated amount of downtime is 3 hours (we are expected to be back up at 1:00 PM MST). Thanks for being a part of the iBoats community!
2 of 2 < >
See more
See less
Wiring help for 1963 28 HP Johnson
  • Wiring help for 1963 28 HP Johnson
    Hi,
    I picked up 14' 1970 sears boat and a 1963 johnson 28 hp outboard for $300 and now I'm trying to get the motor up and running. I'm going to get a set of johnson controls, probably the shipmaster ones. There are 4 wires coming out of the engine (Other that the large battery + and -): red, white, black and green. I believe the red is choke. ANy ideas on what the other 3 are? Do I need a solenoid? Any other pointers on this motor would be greatly appreciated.
    Thanks
    Re: Wiring help for 1963 28 HP Johnson
    Forgot to mention it's a RX-11A if that helps
    • #3
      The wires mentioned sound like the key switch wires. I linked a schematic for you. Also, you will need a solenoid. I included a link to a pic. Btw, I'm working on a RX-10. Just waiting til the ice melts to test it out.
      jasper
      '77 Crestliner Voyager Deluxe 16' (semi V), Spartan WondeRoll tilt trailer, '81 Johnson 25 hp, '88 Johnson 30 hp, '87 Evinrude 30 hp
      • #4
        do you know a certain part number or type of solenoid I need?
        • #5
          http://cgi.ebay.com/ebaymotors/Electric-Start-Solenoid-Box-1960s-Evinrude-Johnson_W0QQitemZ170310630639QQcmdZViewItemQQptZBo at_Parts_Accessories_Gear?hash=item170310630639&_t rksid=p4506.c0.m245&_trkparms=72%3A1171|65%3A12|39 %3A1|240%3A1318
          i think i found a solenoid...
          • #6
            yep, that's it.
            Are you doing a remote setup?
            • #7
              yeah it will be a remote setup. I just need the solenoid right? Do you know what part number it would be?
              • #8
                No, sorry can't help you there.
                edit: Hopefully one of the experts will chime in with a part number for you. You may be able to get one here on iBoats.
                • #9
                  http://www.iboats.com/mall/partfinde...=092866399&dz=[VE::Template%20can't%20find:%20dz]&gd_grid_id=541&gd_partfinder=1&gd_poid=111828&gd_ row=15&**********=418025774
                  • #10
                    I have a manual for a 1968 Johnson 33hp motor, which is essentially the same motor as yours. While I have to caution that the wiring may be different than yours, it probably isn't.
                    The short answer is that the white wire (16 ga.) runs between the start terminal on the starter solenoid and the "S" terminal on the key switch, the black wire (18 ga.) runs between the center terminal on the vacuum cutout switch and one of the "M" terminals (the one between the "S" & "Bat terminals) on the key switch, and the green wire (12 ga.) runs between the hot side (red) of the starter solenoid and the "Bat" terminal on the key switch.
                    On my diagram, however, the choke circuit has a red/white wire (16 ga.) running from the choke switch to the choke solenoid. The choke switch is fed by a solid red wire (16 ga.) from the "A" terminal on the key switch.
                    Also, there should be a black/white wire (18 ga.) running from the other "M" terminal to the black wire (18 ga.) that runs between the coil lead assembly and the center post on the vacuum cutout. That wire is spliced to the black wire with a wire connector.
                    You didn't mention a generator and voltage regulator, but if the motor has/had them, there will be a brown wire (12 ga.) that runs from the "Bat" terminal on the voltage regulator to the "Gen" side of the ammeter. The "Bat" side of the ammeter will have another green wire (10 ga.) that runs back to the "Bat" terminal on the key switch. Notice that this green wire is 10 ga. instead of 12 ga., as was the case with the first one.
                    I have a couple of these motors, but haven't looked at them in a dog's age, so I am providing this info purely from the wiring diagram.
                    Please don't PM me on advice issues - let's keep that in the forums, so that everyone can benefit. Please note that I do not email PDFs, etc. I have a bandwidth limited aircard for internet access. My avatar does not mean I have any offical link to iboats. I just like it!
                    • #11
                      the chart with solenoid part numbers does not cover 1963, is it the same for all 28 hp models?
                      • #12
                        this one will work just fine. http://www.iboats.com/mall/partfinde...****=604924179
                        poor quality job but it worked.
                        FLORIDA GATORS
                        TEBOW Country
                        Please, NO PM's (Private Messages) regarding boat/engine problems. they will not be answered.
                        That is what these forums are for. Post your questions, in the appropriate Forum.
                        • #13
                          thank you guys so much for your help! I'll let you know how it works out
                          • #14
                            ok, I'm trying to wire it up on the stand so I can work on it. I have the starter solenoid wired up and that works . I know the red wire coming out of the engine is positive for the choke solenoid and that works. That leaves the following wires.
                            White- I think this should get positive to go to vacuum cutout and safety switch
                            2 black wires- one goes to the vacuum cutout the other to the kill switch. Are these both grounds?
                            im putting switches on the wires so I can test it on the stand but something is wrong because I'm smoking the switch. PLEASE HELP!
                            • #15
                              got the white wire figured out. Still working on the 2 black wires. I figured that had to be the + for the ignition so I hooked it to battery positive. Using a spark tester I noticed that even when the motor wasn't cranking over there was constant power going through the plug wires. This made me think that maybe something was wrong with the points, maybe they were grounded out. Then I disconnected the spark plug wire and smoke came from the points I'm really stumped here. I went ahead and ordered the points tune-up kit but still cant figure out how to get this thing running
