Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
1 of 2 < >
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 10 AM MST on 12/16/2017. The estimated amount of downtime is 3 hours (we are expected to be back up at 1:00 PM MST). Thanks for being a part of the iBoats community!
2 of 2 < >
See more
See less
Help with Evinrude 1974 4HP
  • Help with Evinrude 1974 4HP
    Hi, would appreciate some help. Cannot get Evinrude 1974 4HP (Mod No 44B36R) to run. Have a similar 1979 motor and have proved carb and magneto by exchanging on other motor. I have good equal compression on both cylinders (105psi), I have a good spark and sometimes get an occasional fire. Plugs do not appear to get very wet. I have removed reed valves and they appear to be fine. I get the feel there is not alot of crankcase vacuum, not much 'sucking' noise from the reed valves. Don't think the top crankshaft seal has gone as its very clean under magneto, there does not appear to be a bottom seal according to the manuals I have? Don't know how to check for crankcase vacuum without opening and checking seal. Has anyone got any ideas.
    Thanks
    Ceno
    Re: Help with Evinrude 1974 4HP
    will it start if you spray premixed fuel into the carbs? is the choke closing?
    FLORIDA GATORS
    TEBOW Country
    Please, NO PM's (Private Messages) regarding boat/engine problems. they will not be answered.
    That is what these forums are for. Post your questions, in the appropriate Forum.
    • #3
      Thanks for getting back,
      I've tried squirting premix with a syringe in through carb and through plugs and only get the odd fire. I maybe flooding it though, how is best way to get a spray. Carb (and choke) is working fine on other outboard.
      Ceno
      • #4
        I thought the same thing about the crankcase vacuum when I had trouble with my 1970 4 hp a couple of years ago but that appears to be normal. In my case it was the carb which I took apart probably 4 times and finally installed an overhaul kit before it ran right.
        Here's something you might look at. I've had my 4 hp since 1974 and from experience one of the first things I look at when the motor acts up is the bottom spark plug wire. The motor cover had a habit of hitting that wire when you remove/install it. I've found that the boot can be pulled loose from the wire after awhile. I now wire tie the boot to the wire.
        Don H
        • #5
          Except for the carb and a few bits in the magnetos those two cylinders are independent 2 stroke engines. Whatever is preventing it from starting is something they share.
          sigpic
          • #6
            Just use one of those trigger spray bottles with pre-mix in it. I would hold off on putting it in the cylinders as that could more easily wet your plugs so much they won't fire. It could be that you still have to adjust the low speed needle a bit when you switch the carb. to the 74 motor. Try turning it out in 1/4 turns all the way from 1 turn from home till you get to even 2 1/2 turns from home. That will richen things significantly provided your carb. is functioning well. These are great motors and I'm confident yours will run again soon.
            • #7
              Ceno
              Get a pump spray bottle like the type we use for some cleaning products. Look for a recycle code "HDPE 2." This should be OK to not react to the gasoline...Let a small bit before sit in the bottle before you try spraying it in the carb...just to be sure (you do not want any dissolved plastic shot into your carb!). Also, make sure the bottle you choose has been cleaned throughly to prevent a chemical reaction with previous products. Furthermore, it's not a good idea to store any of the pre-mix in that bottle...drain any left over back in your tank and label the bottle as "Gasoline" to prevent any mistake about its current or previous contents.
              MAS
              "New" '57 Lark Chapter One...the Find:
              http://forums.iboats.com/showthread.php?t=370037
              "New" '57 Lark Chapter Two...the Initial Breakdown:
              http://forums.iboats.com/showthread.php?t=370666
              "New" '57 Lark Chapter Three...the Gearcase:
              http://forums.iboats.com/showthread.php?t=370904
              "New" '57 Lark Chapter Four...the NOS Powerhead:
              http://forums.iboats.com/showthread.php?t=456868
              "New" '57 Lark Chapter Five...Repainting:
              http://forums.iboats.com/showthread.php?t=523546
              • #8
                i do as above, or if a bottle is not available i keep a 18" piece of small fuel line, i just dunk it into the tank, put my thumb on the end. and use it to put fuel into the carb.
                FLORIDA GATORS
                TEBOW Country
                • #9
                  OK its sorted, I bought this as a non runner a few weeks ago from a guy who couldn't get it going with the idea it would be useful as spares. Anyway it looked all there, so I thought I'd try and get it going. I rechecked magneto and carb again on known good motor and reassembled. As discussed earlier I sprayed premix into carb but still only got odd firing. Plugs still never got really wet, so I removed reed valves again. Gaskets came away easy again as they were only stuck on one surface with gasket glue. It was then that I realised the front and back reed box gaskets were switched and was now pressing on reeds stopping them working! Gently peeled gaskets of, cleaned them and replaced correctly and reassembled. Ran first pull! Don't know how long it had been like this, but I reckon it would never have run properly. If only I'd have noticed first time I had removed them.
                  Thanks for everybodies help, it really helped me focus on the problem.
                  Ceno
                  • #10
                    attention to detail. good eye. congrats.
                    FLORIDA GATORS
                    TEBOW Country
