Re: 1977 115 evinrude choke
i have the plunger, with the spring under it, i also have a thin bar comming from the lower carb that attaches to the plunger. i am not understanding where the actual solenoid mounts. it has a bracket around it, unfortuantly, on the side of the manifold, is the oly place i can see it sitting, but in interfears with the linkage in both holes. am i missing a bracket? i bought the entire unit (carbs, cover/manifold, and choke off e-bay) there was a piece of broken bakolite on the manifold/cover in one of the three holes on the side the choke is mounted.
