Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
Anyone have link to OEM manual-2001 -90 HP Johnson?
  • Anyone have link to OEM manual-2001 -90 HP Johnson?
    Hi
    Does anyone have a link to an OEM manual for a 2001, 90 HP Johnson? I have the Seloc manual for it but have heard it is sometimes inaccurate and want to double check procedures before working on my engine.
    Also, what is the proper torque spec for engine mounting bolts to aluminum transom? The idiot so called marine mechanic who mounted my engine originally put the bolt heads inside the boat and the nuts are outside: how could he ever torque them properly?
    Thanks
    JP
    Re: Anyone have link to OEM manual-2001 -90 HP Johnson?
    http://www.outboardbooks.com/
    Please no PMs. My mailbox is full anyway......
    • #3
      as whaler noted, seloc is the keep your knees clean when changing lower unit oil, clymer is to keep the oil from dripping on the driveway.
      FLORIDA GATORS
      TEBOW Country
      Please, NO PM's (Private Messages) regarding boat/engine problems. they will not be answered.
      That is what these forums are for. Post your questions, in the appropriate Forum.
      • #4
        Originally posted by jplomeo View Post
        Hi
        Thanks
        JP
        Not sure that I have ever seen a torque value for those....they should be "just tightened enough"....
        As far as the orientation, I always put the head inside so that the excess thread is not sticking out inside the boat waiting to impale something or someone.
        Why would this affect abilty to torque them? You still need a wrench on the head and the nut....
        You do not need a parachute to skydive. You only need a parachute to skydive twice.
        I don't belong to an organized political party. I'm a Democrat. (Will Rogers)
        • #5
          most are with the head to the inside, makes it easier to adjust engine height if necessary. bolts usually have a plastic cap on them, for safety.
          FLORIDA GATORS
          TEBOW Country
          • #6
            Hi
            Thanks
            JP
            Did you get your manual? If not I have one I bought a year or so ago. It's PDF.
            • #7
              Two year old thread....
              • #8
                PDF manuals are junk.
                sigpic
                See FAQ Files.
                http://forums.iboats.com/showthread.php?t=299680
                Get the genuine factory service manual.
