travelship
- Jan 14, 2009
- 18
I have a 1976 Evinrude 70hp. Which is the better repair manual? Or do I need/should I get both? Or is something else even better?
It is possible to check availability of official parts From this site although other parts may also be available else where.Are parts still readily available for this engine?
this is the manual you want, http://www.iboats.com/1976_Johnson_O...view_id.440577
garbage v. junk.
Also beware of what you get on ebay because they like to sell the "factor service manuals" on cd and they turn out to be Selocs or Clymers copied and put into pdf (that you cant even search in). Just ask questions and make sure of what you are getting.
