Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
1 of 2 < >
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 10 AM MST on 12/16/2017. The estimated amount of downtime is 3 hours (we are expected to be back up at 1:00 PM MST). Thanks for being a part of the iBoats community!
2 of 2 < >
See more
See less
Adding Electric Start - 1984 Johnson 25 HP?
  • Adding Electric Start - 1984 Johnson 25 HP?
    Is there some kind of "kit" that can be purchased to add electric start to a 1984 Johnson 25 HP short shaft tiller? It's not that hard to start, but it sure would be nice to turn a key and go rather than standing up to pull and to be honest outboards of this vintage and HP are not, nor were they ever easy to start cold. I started thinking, I'm carrying the battery (for the trolling motor) so why not just get electric start?
    Over time I've figured out the right prime/choke/pull sequence to start it in as few pulls as possible, but the old girl is cold blooded and in Canada last year when the night temps got to 35, she was a real pain to get running in the morning.
    By "kit" I mean something that would give me the ability to add the electric start by myself, so I guess I'm looking for some way to get all the right parts and instructions in one go.
    I'm sure a mechanic could order the right parts and do it for me, but I'm also pretty sure I wouldn't want to pay the kind of money that would cost. In addition to adding the starter (and I'm assuming there's an alternator involved as well?) and hooking up the wiring, there is the question of where does the ignition key switch go on a tiller model of this vintage? Is there a cutout for it on the flat panel down by the choke and stop button on the front of the outboard? Or does it need to be mounted elsewhere in the boat?
    Grouse
    Re: Adding Electric Start - 1984 Johnson 25 HP?
    yes there is, http://shop2.evinrude.com/ext/index....cfd8a6471c0f7f
    FLORIDA GATORS
    TEBOW Country
    Please, NO PM's (Private Messages) regarding boat/engine problems. they will not be answered.
    That is what these forums are for. Post your questions, in the appropriate Forum.
    • #3
      Does the "starter motor assembly" include everything necessary for the conversion?
      1989 Bayliner Ciera 2150, 5.8L OMC;
      1975 Johnson 6;
      Saturn SD365, 2009 Yamaha 15 2 stroke.
      • #4
        Thanks for the replies.
        Tash, the link doesn't really bring anything up, did it get cut off by chance?
        I guess I have the same question as JS, does that assembly include everything?
        Grouse
        • #5
          NO the kit # is 173964 $407.00 then you need battery cables, and ignition harness.
          FLORIDA GATORS
          TEBOW Country
          • #6
            you may be better off selling what you have, and buying what you need.
            FLORIDA GATORS
            TEBOW Country
            • #7
              Looks like we got two threads going here. Anyhoo, once you get to the shop2.evinrude site click on the drop down box where it defaults to Evinrude. Then select OB Accessories. Follow the prompts till you get to the kit for your motor. It will show everything that is included. It will include everything you need and should include instructions with the kit.
              • #8
                Thanks, I see it now. Looks like I'd be signing up to about $425 to add it at this point.
                That's a pretty tough one to swallow for a 1984. I was hoping it'd come in around half of that to make it worthwhile.
                Considering a used 4 stroke 25 can be bought for around $1500, it's tough to justify putting that much money into an 1984, I think. Oh well, better hit the gym and bulk up so I can pull that ripcord for a few more years.
                Grouse
                • #9
                  yeh, you can buy a lot of bait and gas, for that $$, find a teenager that likes to fish. there is you automatic starter.
                  FLORIDA GATORS
                  TEBOW Country
                  • #10
                    when you consider the cost of feeding a teenager the electric start will be cheaper, more dependable, and talk back less. but not nearly as much fun.
                    • #11
                      i mean a neighbor kid, or grand kid. every time i go fishing, i take one of the neighbors kids. their only exposure to it. they all love it.
                      FLORIDA GATORS
                      TEBOW Country
                      • #12
                        Might be worth poking around the local marinas - if they're even open this time of year, and see what they have in the back room or basement. Might be able to find a blown 1980s era 20-35 with the parts you need for less than the kit itself... With the way the economy is the marina guys might be willing to deal just to get some cash coming in.
                        - Scott
                        Share A Project Page for 1971 GW Invader Banchie 13
                        http://www.shareaproject.com/pages/p...,p,433,00.html
                        Share A Project Page for 1976 American 18
                        http://www.shareaproject.com/pages/p...,p,404,00.html
                        Share A Project Page for 1974 American 15
                        http://www.shareaproject.com/pages/p...,p,405,00.html
                        • #13
                          I have an '81 25hp. When I get tired of yanking the cord, I would sell or swap it for something else. Cost too much to add a starter.
                          '77 Crestliner Voyager Deluxe 16' (semi V), Spartan WondeRoll tilt trailer, '81 Johnson 25 hp, '88 Johnson 30 hp, '87 Evinrude 30 hp
                          • #14
                            lol a teenage likes fishing... a big strong sexy guy sounds right! u know what it sounds like me
                            -1964 20Ft Riviera Cruiser, 1961 14.5Ft Critchfield, 1962 15ft Orlando Clipper
                            -1959/60 10 Hp Evinrude, 1961 Mercury 500, 1958 35 Hp Johnson (Sold), 1990 25 Hp Johnson (Sold), 1985 60 Hp Johnson
                            1962 Orlando Clipper 15FT http://forums.iboats.com/showthread....hlight=orlando
                            http://photobucket.com/sgdteam
