Mas
- Oct 3, 2006
- 1,656
The pull starter wire/rope on my seahorse is in need of attention. The wire is sheathed inside "hollow rope" that has separated exposing the wire & leaving threads all over the place. I'm worried that all the little threads will cause a problem somewhere (carb, magneto, etc.).
It seems that I could just replace the "rope" part by fishing my existing wire into something similar. The rope seems to be a little heavier than shoelace.
Any ideas of what I could use on the cheap? Again, shoelace was my first thought, or do I need to look for an OEM replacement?
Thanks
MAS
Thanks
MAS
