I bought an old bass boat with an 115 hp Johnson (115EL77S). I've been slowly replacing/repairing stuff on both the boat and motor.
I've gone from the engine not running at all to running poorly to running OK but not getting to proper rpm at WOT.
My current problem is that the brass fitting that is pressed into the float chamber assembly on the bottom of the upper carb keeps popping out. I'm getting ready to pull and rebuild the carbs and have a few questions.
What is the proper technique to press that fitting into place?
Do I need 2 rebuild kits (one for the upper and lower carb)?
Thanks,
Brian D
Thanks,
Brian D
