hawkman222
- Feb 20, 2006
- 45
Last spring I tore down and rebuilt a 1984 90 Hp crossflow. I saved 3 pistons and connecting rods from that motor with the hopes of using them at a later date. The pistons are Wiseco 3173P3 's, .030 over, and mic out well for round. I now have another V4 I'm working on and am thinking about using these pistons. I removed the wrist pins to check the rod small end and bearings. It didn't take much effort to remove the pins, and when I reassembled them, I could almost press the pin clear in with just my fingers. The fit is snug, but compared to the cast pistons I've used in the past, these pins seem loose. Is the pin fit looser in forged pistons than cast? Should I reuse these pistons or junk them? Would buying new wrist pins make for a more snug pin fit? Thanks!
