Re: Seized 2001 Johnson 115
It Can Still Be The Lower,but That Is A Bit Unlikely If It Spins In Neu.if The Engine Was Run And Didnt Have Gear Lube In Lower,or If Water Was In Lower ,you Could Have A Bearing Seize,usually If A Connecting Rod Broke You Would Suddenly Hear A Knocking Like A Hammer,then Rod May Stick ,or During A Heat Seize You Hear A Metallic Slowing Grinding Type ,but Of Course I Blew Up A Few So Would Be A Little More Aware.you Can Start By Pulling The Lowerunit.or Find Something To Turn The Flywheel,pull The Plugs Out,look For Any Kind Of Unusual ,metalally Deposits On The Plug,if You Do Then Just Go Pull That Cyl Head Right Off,plugs Will Usualy Tell You If You Had A Piston Detonate,or Water Rust,if For Some Reason The Eng Didnt Get Oil,that Would Heat Mains Up Too,but Usually The Cyl Will Sieze First.i Realize I May Be All Over The Place In Sequence,pull Plugs Forst,then Try And Turn Flywheel With Wrench,if Its Totally Locked,pull Lowerunit,still Locked Heads,but If A Plug Shows Bad,go For Heads First,get Back With Finding
