Re: Johnson paint color
Just did mine. Here are some pics. I used Moeller Zinc Chromate primer(yellow) 1 Can, 1 can Tempo (Evinrude Sea Drive Silver 1983-1986) Part No. 020462, and 1 can Moeller Clear Coat.
I cleaned it up with a wire brush and simple green, sanded it down with 220,320,400 grit. Used the whole can of the primer on it, then started with the paint and used the entire can...plus a little more. Used #0000 steel wool between coats followed up by a tack cloth. Finished off with about 3 or 4 coats of clear. Hope this helps someone. P.S. Don't try to use every last drop in the paint can...it isn't pretty and the overspray with the yellow primer will leave a powder on everything. Oh, and I purchased my paint from West Marine.
www.westmarine.com
Good Luck!
