I just picked up this 1988 88 HP SPL (which supposedly is a 90 HP without VRO). It seems to run okay but when throttling up it seems to surge with a lot more power for a few seconds and then backs down again. Could this be the carbs not working properly or is it an indication of ignition cutting in and out?
Again it starts fine--seems to idle well but apparently is not running as strong as it should.
An unrelated question - I notice that when I first start it there appears to be bubles coming up from where the prop is located. never noticed that before on my 85HP. Is this an indication of exhaust getting where it should not or potential water in lower end?
Thanks
Thanks
