Store Links Mobile - Shop Now
1 of 2 < >
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 1 PM MST on 12/16/2017. The estimated amount of downtime is 3 hours. Thanks for being a part of the iBoats community!
2 of 2 < >
See more
See less
Rebuilding LU. Perfect Seal #4 & Sealer 1000 Substitutes?
  • Rebuilding LU. Perfect Seal #4 & Sealer 1000 Substitutes?
    I was planning on putting my lower unit ('58 Johnson 35hp) together this weekend. I don't have many local boat stores and need substitutes for the below:
    My Glenn's Marine Manual references using 'Sealer 1000' on seals and 'Perfect Seal #4' on bolts. Are there acceptable automotive substitutes for these out there?
    (Like Permatex black and loc-tite?)
    Edit: Per the local Mercury dealer the perfect seal #4 was put on the bolts of the lower unit to reduce corrosion. (Minimize the Stainless bolts from corroding the Aluminum unit). So loc-tite is probably not the right stuff...
    So far on the forums I have seen: 3M #847, Permatex #300 Aviation, Permatex Black or Blue, as substitutes for the Sealer 1000.
    Not much discussion on the 'Perfect Seal #4' otherwise known as 'Johnson Gasket sealing compound' that is recommended for use on bolts.
    Edit #2: From auto store trip I am using VersaChem 'Prime Seal Gasket Sealant type 3 aviation' in place of Sealer 1000 and Permatex 'High Temperature Thread Sealant' for the Perfect Seal #4. Both of these seem to fulfill the requirements, though the 'High Temperature' is not necessary it does protect against corrosion and provides some resistance to vibrating loose.
    Re: Rebuilding LU. Perfect Seal #4 &amp; Sealer 1000 Substitutes?
    Perfect seal #4 has given way to BRP "Gasket Sealing Compound" PN 317201 or 508235.
    Mercury sells Perfect Seal sealer under their label: Quicksilver 92-34227-1.
    The current product for sealing the gearcase is 3M Scotch-Grip 847 which is sold by BRP as part number 776964.
    Click the BRP thumbnail below for description.
