jbjennings
- Jul 18, 2007
- 3,903
Here's a little info. for those who may need it on how to get good spark on an old OMC (50's, 60's, and some 70's models).
I hope some real experts like F-R will double-check my post, pretty please so noone gets any bad info from me or if I forget something.....
Here's a pic of some cheap tools and such you'll need to remove the flywheel and such:
Make sure you use hardened 1/4-20 bolts, available at any decent hardware store. Screw them in the 3 holes that you will see after you take the ring off that the pull starter pawls grab onto when starting it.
then use a 5/8 socket to tighten the harmonic balancer puller. Be sure the flat side of the puller is up. A pic of the puller setup is shown in the second pic. You'll have to tighten the heck out of it sometimes until the flywheel pops off. The flywheel hole is tapered which makes it wedge down when you tighten the flywheel nut. Never beat on the flywheel to remove it or you will ruin the flywheel! Be sure to tighten it to specs. with a torque wrench when you reinstall it or your flywheel key might shear off.
