javelinjay1
- Jun 1, 2008
- 16
When ever I advance throttle port side bank cuts out(no spark) although it idles in and out of gear with spark to both sides. Checked shift interrupter swith and it is fine. My OMC manual says my stator should have a resistance reading for each coil between 1000 and 1200 ohms. I only get 450 and 458 ohms. Another forum I seen said 450-600 is correct. Who is right? Cranking voltage off of the two coil wires(brown/white-brown/black , brown-brown/yellow) indicate 128 volts cranking with regular voltmeter not a fluke meter and stator is not shorted to ground. Just wondering do I replace the pack or stator? To me it sounds like the pack if resistance is correct. Can someone please verify with me.
Thanks for any help.
Jay
Jay
