asdasc
- Aug 28, 2008
- 680
I have a quick question after reading the Carb Adjusting FAQ by J. Reeves. Is it important to tune the high speed prior to tuning the low speed? I was out by myself so could only tune the low speed. It seems to run fine at idle, but has very little increase at the top end, so I need to get another person with me and make sure the throttle is going full open, and then tune it at WOT. Before doing the Hi-Speed, should I put the low speed back to the initial settings?
Also, I was amazed at the oil slick you get after shutting the engine down after a slow troll down the canal to my dock. Is that pretty normal?
Overall it runs very smooth and starts on the first or second pull.
It is a 1959 Johnson 18HP.
Thanks,
Thanks,
