JoeMan
- Jun 29, 2006
- 322
My friend has a '56 30HP Johnson outboard which he just got running after 20 years of sitting. According to the info he has on it, this motor originally had a 24:1 mix ratio using the lubricants available in 1956. He is currrently running a 50:1 mix ratio using Redline Two Stroke Racing Oil (synthetic). The engine runs quite strong, achieving 24 mph using GPS. The plug color is excellent. The Redline directions recommend mix ratios of up to 100:1 using
this lubricant. He is quite hesitant of going any higher than 50:1 in fear of creating too lean of a mixture. I am sure other folks have been running modern lubricants with old outboards and can easily answer this one.
Thanks!
JoeMan
Thanks!
JoeMan
