richardg123
- Sep 16, 2008
- 5
Hope Someone Can Help!!!!
My Engine Put Pick Up Spped It Seems Very Slugglish, And Has Misfire At Idle.
I Have Changed The Plugs,gapped Them, Cleaned Carb,new Fuel, Checked For Fuel Leak, Stripped Pump All Ok,cleaned Points. Adjusted Mixture. Checked Compression!!!
Any Other Ideas.
Please Can You Let New If I Have Done Timing Correctly. Please Can You Explain The Process That Should Be Carried Out So That It Has Been Done Correctly.
Thanks
Any Other Ideas.
Thanks
