Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
1980 Johnson 75 Stinger No Spark
  • 1980 Johnson 75 Stinger No Spark
    So it was my turn to use the boat sunday. My brother said that it idles great but has no power at full throttle. Not missing, just no power. So I was going to change the plugs to see if that helped. Then I got a call in the morning that the battery was dead and the engine was not charging. I should bring a battery with me. So I brought a battery and plugs. After the 1 hour drive to the boat, I proceeded to try and start it. Battery was dead. Changed the battery. Now it cranks great, but nothing. So I pull the plugs and they are soaking wet. Definately gas. So I change them and still nothing. I have no spark at all. So I think that on this engine, the stator charges the battery and the coils. But I also understand that there is a stop circuit. My questions are how do I check the stop circuit and how do I check the stator? Am I going in the right direction?
    Thanks
    Andy
    Re: 1980 Johnson 75 Stinger No Spark
    here are some test. http://www.******************/page32.asp
    FLORIDA GATORS
    TEBOW Country
    Please, NO PM's (Private Messages) regarding boat/engine problems. they will not be answered.
    That is what these forums are for. Post your questions, in the appropriate Forum.
    • #3
      A great tip that I got on this forum was to unplug the big red plug and jumper out the starter. If you still don't have spark it is on the engine if you have spark then it would be something such as you kill switch or stop circuit. Worked great for me.
      • #4
        Thanks for the info Tashasdaddy. This will help alot. I'm going back to the boat tomorrow and will repost my results. Thanks again.
