To say the least I thought I like many have replaced everything on this engine to make it as close to as new as I could. Here is the list of replacement parts.
Coils, points, condensors, plugs, plug wires...Engine wiring harnes, new fuel lines, rebuilt carb, then had it set and linked by a professional shop. Lower unit resealed, along with a new water pump.
So here is how the problem came about. The engine fired and idled flawless, then all the sudden it would just cough then idle for 5-8 more seconds then cough. It would do this until the I brought the rpms up to the 1k range. It would do this in or out of gear. The engine would run fine all the way up to full rpm. I finally stopped and opened the inspection door and noticed that when the engine coughed it would squirt fuel out around the hose and the hose barb on the carb. I replaced the origional wire type hose clamp with a small screw type hose clamp. That solved the fuel leak, and about half of the cough problem. I had to richen up the low speed needle 1/8 turn to solve the coughing. I will admit that the fuel was purchased in late May and had stabil added at the same time. What do you believe caused the coughing, and is what I did the correct way to solve it?
Second problem of the day
A little time passed and it started to feel like it the prop was cavitating. I checked the rpm no gain, pulled the prop, no slipping of the hub. Then for some reason I checked the primer bulb. It was dry. After no joke over 100 pumps on both tanks it wouldnt take prime. I could hear the fuel being drawn into the hose "not the bulb" then it fall back into the tank. I finally held the bulb vertical and rapped on the check valve end with a screwdrive and it took prime. This solved the cavitating feeling. I am guessing that the check valve got stuck. Is this common or a common thing with Walmart primer bulbs?
Thanks for all your help and I am sorry for the long post. Here are a few pics of the engine fully restored.
