Re: When did Johnson start using black paint?
I have a 1996 115 johnson and that is also the charcoal grey color, not sure when they started that, It might have been a option. Here's the code that omc/bombadier uses to identify the motor years from 1980 on up.
I N T R O D U C E S
1 2 3 4 5 6 7 8 9 0
Look at the model number and the second and third letter from the right or end, match up with corresponding number, for the year.
Example: model #J115eledr
So you match up the E and D with the numbers above and it tells you it's 96.
