MrGED05
- Jul 25, 2008
- 50
Sirs:
I recently purchased this outboard. After much effort, I've repaired the transmission and replaced the impeller. Now I've managed to get the motor to run but very badly, it needs about half choke to keep running and won't pull WOT revolutions as it should.
Carb rebuild in process now. I ordered the manual, it should have gotten here Friday. It didn't. Naturally. I reserved today to do the rebuild (I bought an original Johnson carb overhaul set: gaskets, needle valve and seat, jets, the whole package)
Since I have today to do the job, I started pulling the carb. First off was the flywheel (bought a nice gear puller so I could use the tapped holes in the flywheel instead of taking a chance of damaging the starter rope channel or the starter teeth). I've removed the bolts I can access.
The spring loaded, flexible shaft choke mechanism is new to me, I've no idea the proper way to disconnect and remove it. Also, any hints on proper float settings and such would be appreciated.
Anyone care to share some advice with me?
Thank you in advance,
Gary
Gary
