Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
1988 175 hp Johnson Water Flow Diagram
  • 1988 175 hp Johnson Water Flow Diagram
    I am having a heating problem with the right bank of cylinders on my 175 Johnson. I have changed T-stats and pressure releif fittings and pulled water jacket cover plates to check for blockage and everything is clean. I am having a little problem finding a schematic/diagram that shows the water flow for that motor. My next endeavor is to pull the right head and check the water deflectors but I would like to check the water flow before I pull the head. Anyone know where I can find water flow diagram for that motor?
    Thanks...
    Re: 1988 175 hp Johnson Water Flow Diagram
    The water flow diagram is in the service manual. Pull both heads. You'll end up needing to replace all 6 deflectors.
    • #3
      Thanks for the info. That was what I had suspected.
