Hi there, I have a 1967 60 hp Sportfour Evinrude. I have done quite a bit of work to this engine, seals, new wiring harness etc. to get it on the water. I now have it seemingly running pretty well, however it is extremely doggy in getting going. With my wife and 2 daughters, I have to lean over the bow to get it to step up on plane, and even then it takes quite a while. It moves along pretty well once it's up and going. Around 30 mph+ I do not have a tach on it, so I am not sure of the rpm. I know I need to be cautious of over-revving, but does this sound typical of have the wrong prop for some get up and go? When just my brother and I are on it, it is still sluggish but not nearly as much. I checked compression, and it seems reasonable, peaking a little over 100lbs, and pretty well balanced. I don't know how super accurate my tester is, but the cylinders seem to be within a few pounds of each other at the most. The motor is on a 1967 15' Starcraft runabout.
