Re: How to disconnect lower unit from motor on 1957 5.5 Johnson to change impellor
1. Disconnect fuel & air hoses.
2. Remove the vertical throttle control shaft (not necessary, but it makes reassembly easier)
3. Remove the 7 screws holding the powerhead on. Note location of the slightly longer ones.
4. Lift powerhead off.
5. Two nuts with a lockwasher between them hold the shift rod.
When you put it back together, use a new powerhead gasket and a NEW 303355 gasket and 303347 o-ring on the carbon seal assembly. That seal assembly is a vital part and must not leak.
