Re: evinrude model number and year
Be careful about that fuel mix. The light Twins are still a friction type motor and should be run at 24:1
50:1 mix is for the non friction type motors only.
Unfortunately, the people who designed the Light Twins goofed on this one, even though they built a great motor. The old motors of the 50's were rated at 24:1 and changed to 50:1 in 1964, but the Light Twin was not redesigned as a non friction motor to allow the lighter oil mix. Even the 1 1/2hp was built with the needle bearing set up and allowed for the 50:1 mix, but the 3 and 4hps were still built with the old style crank and rod assemblies from 1953
Just look at your repair manual and you'll see how they're built.
