Help identifying a vintage Johnson motor
Chipster_82
I purchased an old Johnson motor at a rummage sale. I was told it was a 5 Hp --- no engine cover -- no spark plugs. (The gas tank is on top behind the pull cord) Motor is painted dark green. I'm looking for as much info as I can get on this motor. The only numbers I found on stamped on the engine block: Serial number 955517 & Model TN28 Any idea what year ?? Horse Power ?? Which spark plugs to buy ?? etc.... I'll send a picture if someone would like to see it !! Thanks. Chip
motofix
Re: Help identifying a vintage Johnson motor
I have a 7.5 hp Jonson 2 stroke 2 cylinder serial c8193449 dont know modle,
and would like to know the age
F_R
Need the model number. But it probably is between 1980 and 1983. Please start a new thread if you have other questions and you will get better results.
