i replaced the impellor on this motor a month or two ago because it wasn't moving water. the new impellor worked great as i was running it in a water barrel then it stoped working and i found the rubber impellor torn to pieces. did i do something wrong? i thought i kept enough water in the tank to feed the pump.
