Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
2000 130 hp johnson overheat alarm
  • 2000 130 hp johnson overheat alarm
    My 2000 130 hp ocean pro johnson will sound the overheat alarm & light after
    running under load for about 10 minutes. The engine is running at 130-138
    degrees.What is the problem?
    Re: 2000 130 hp johnson overheat alarm
    If you are sure it is the overheat and not fuel restriction, check the heat sensors as per your manual. How are you verifying the temp? May be a t stat stuck shut.
    Chris
    Top Secret Files:
    http://forums.iboats.com/showthread.php?t=299680
    PROUD NOW OWNER OF SITE DEDICATED TO ANTIQUE AND VINTAGE OUTBOARD
    • #3
      i did verify temp properly last night under load with temp gun. It is in fact overheating on the port side. Tapped on the theremostat cover & temp gradually went down. Possibly a sticking thermostat ???
      • #4
        replaced thermostats , fixed problem.
        • #5
          Glad that you got it! Thanks for the update as well, would be nice if more did the same, as it is always nice to hear how things turned out.
          Chris
          Top Secret Files:
