Zoomie
- Jun 29, 2008
- 3
I am going to ?make ready? a 1985 Evinrude 15 Horsepower Model Number E15RC0B outboard for a friend. This motor has been in storage for 10 years. The engine was used very little prior to storage.
Ignition spark is strong. Compression is 90 PSI (cold) on both cylinders. To my knowledge OMC did not publish compression specifications for this engine. I believe they just said you should not have more than 15 percent difference between cylinders. I will perform a leakdown test tomorrow.
I briefly ran the motor. It started easily but runs poorly. I see no water discharge indicating water pump operating.
Below is a list of what I will do to the engine. Is there anything I am missing?
Questions:
Any comments or tips are appreciated. I have extensive experience in a variety of small engines and aircraft piston engines. Long ago I took classes in outboard repair.
- Clean the carburetor and install repair kit parts.
- Clean the fuel pump and install a repair kit.
- Install water pump kit.
- Replace fuel lines.
- Replace spark plugs.
- Install new thermostat.
- Remove carbon from head and piston and replace head gasket.
- Replace oil in gear case.
Questions:
- Does anyone have a PDF service manual for this engine? I have many PDF small engine and outdoor power equipment service manuals to trade.
- I use ?Valucraft Carb Cleaner? Part Number: AZ-4, from Auto Zone in my small engine business. This is an aerosol cleaner that is the best I have ever used. This stuff will melt away varnish. On the down side it will damage some rubber and plastic parts. I have heard some carburetors on outboard engines were made of a porous metal and sealed with a sealer. If you use strong cleaners the carburetor can be damaged. Any truth to this? How about the carburetor on this engine?
- What is the torque for head bolts? Is there a specific torque pattern?
