Xandre
- Jul 18, 2006
- 143
OK I am 99% sure this is a fuel issue. I was out on Lake Ontario yesterday cruising around without issue. I decided to experiment with my rich and lean settings to learn a bit more about what these controls do. After playing with them a bit I set them back to my "normal" setting" and everything is fine.
I went to the dock to pick someone up and then the boat has a hard time starting back up. I struggle to get it going and have to really feed it a ton of gas. I open the motor door and see that when I pump the bulb fuel is leaking out of a hole and going everywhere ( see pic on link).
So the fuel is perhaps getting blocked and thus being pushed out of where it shouldn't?
Any ideas here?
The motar is a 1968-69 Johnson 33 HP Super seahorse
Any ideas here?
