Dewey Hatcher
- Jun 28, 2008
- 4
My 1986 Johnson 60HP indicated a voltage output of 16.8 volts when the engine is running at the higher rpm's, so I purchased a new rectifier/voltage regulator and installed it. The new unit indicates 16.7 volts when running at the same rpm. Is this normal and if not, why would the regulator not be working properly? I am concerned about overcharging the battery. THANKS
