My 9.9 for some reason won't shift into reverse gear. I replaced the brass linkage coupler (it had a broken ear when I unscrewed it).
I manually tried the linkage in the lower unit alone by pushing it up and down, and it seems to work fine- it engages both fwd neutral and rev gears fine, and it works reasonably easy. I'm sure the brass coupler was put on correct. Forward and neutral seem to work as they should, but it is acting like there is not quite enough travel in the shift linkage to engage rev gear.
I've tried adjusting the linkage to every possible setting, without results. Even when the apparatus is unbolted from the engine, and it is free to move to the limits of lever travel, it still doesn't engage rev
This motor is new to me, but I've had other similar motors and never had a problem getting them to shift, or getting them adjusted. Is there any chance either the linkage that goes to the shift lever in the engine, or the rod that goes down in the gear cradle, is somehow out of adjustment?
What would I check?
I have available an alternate lower unit that I can put on to see if that works, but I can't see anything wrong with this one, beside the fact, of course, that it doesn't work.
What would I check?
