lenniefoug
- May 26, 2008
- 13
I first posted a couple of weeks ago and said that my engine was binding up. I was able to move the flywheel back and forth but it keeps binding in the same spot, Based on the suggestions I received I have done the following: pulled the flywheel and checked the magnets; pulled the lower unit; pulled the upper bearing on the crankshaft; and today I pulled the cylinder heads. I am pretty much a greenhorn when it comes to engine mechanics but I can read and follow directions. All 4 pistons are moving which I believe eliminates a broken connecting rod as the problem. Visually I can't tell if there is a problem or not as they are all intact and a pile of metal shavings didnt fall out. But again, this is new territory for me. Just before the problem occured, I started to hear a noise that sounded like a bad bearing which is why I removed the upper bearing. I am really at the limit of my comfort zone but I need to decide if its worth pushing ahead to diagnose and possibly repair or is this a sinking ship that I should give up on.
Any and all opinions or advice are welcome..thanks
