Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
Do all new 4 stroke outboard requre valve adjustments?
  • Do all new 4 stroke outboard requre valve adjustments?
    I was under the impression that the new 4 stroke outboards need valve inspections.
    I have a 2004 115 EFI Suzuki made johnson and I just purchased a Suzuki service manual and it says nothing of valve adjustments, just your basic Oil, spark plugs, fuel filter, impeller ect..
    Does that sound right?
    Re: Do all new 4 stroke outboard requre valve adjustments?
    not too sure about your Motor, but I would reckon a valve adjustment on a Yamaha would be beyond most home handymen.
    • #3
      Right, I would never do that myself but from what I can tell I never have to have it done based on the maintenance chart they provided.
      • #4
        The service manual for my '08 Suzy indicates valve check and adjustment is required. Are you looking at a "Service" manual or "Operators" manual. Big difference. Inspect at 20 hours and every 200 hours after that.
        • #5
          Wow, they still have manually adjusted valves on modern engines? My '71 VW van had those... I thought valves were hydraulic now and required no adjusting. I guess outboards have not caught up to auto's in that area then.
          Steve.
          • #6
            Yeah, I'm also surprised that it wouldn't have hydraulic lifters. Shows what I (don't) know.
            Back to Top
