Hello everyone...! I have a little issue... I have an 1977 evinrude 140 hp outboard. bought the engine with un-known condition. replaced coils, stator, regulator, gaskets, control box for boat, and power pack. Now got it to fire and run, but i have to have the lever all the way up on the control box to start and maintain running it. When i let the lever down it dies right out and is a bit hard to start again. usually have to choke it and then put lever all the way up again. I know the lever control timing right..? Well i see it putting timing all the way forward to keep it running. Any ideas on whats wrong. Also last thing. motor revs fine by moving butterflies manualy, but when i put it into gear it makes a clicking noise and barely moves forward, if i take the little lever off the throttle and move the gear selector manually it goes right into gear. I've been looking in the manual and cant seem to figure this one out. Thanks in advance, Bill.
