I recently bought a used 1982 or '83 70hp Evinrude attached to what I'm guessing is an aftermarket trim/tilt system. The trim tilt has an electric motor with a hydraulic pump, and it has slowly lost it's ability to lift the outboard. The electric motor seems to be running in both the up and down directions. The only information on the tilt/trim unit I could see was "Goldeneye Products" and a sticker on the outside that says "POWER UP".
Anybody have any experience with one of these? I couldn't find anything online for maintenance or repair. If it's low on hydraulic fluid, I'm not sure what, or how much to put in.
Thanks!
Thanks!
