Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
zinc chromate primer at local auto stores?
  • zinc chromate primer at local auto stores?
    Anyone know where I can get zinc chromate primer? I checked couple of local auto store and none of the cans I saw has the words zinc chromate primer on it. Is it called something else?
    I have some regular primer and was wondering after one coat of zinc chromate primer, can I spray regular primer over that? I just want to save some $$$. Zinc chromate primer is expensive. Thanks.
    Re: zinc chromate primer at local auto stores?
    Um, how do you know it's expensive if you cant find it?
    Steve.
    • #3
      ********** has it for $15.99 a can.
      • #4
        West Marine has $10 hose clamps too. Try just doing a web search you may have to order it and wait a bit.
        • #5
          I just bought two cans from NAPA auto parts store locally.
          It is put out by TECnique, part nr 7222, price 9.99, net price 7.49 ea.
          Hope this helps.
          • #6
            Zinc chromate along with other chromates and chromium VI compounds is carcinogenic so is not now as commonly used or available as it used to be.
            • #7
              It's also called self etching primer. Any auto parts store that Duplicolor or Tempo auto paint should have a can...around here they sell it for about $5 a pop for the tall can. Make sure the color coat paint you want to use is compatible...it's best to stick with the same brand/chemistry from primer through clear coat.
              • #8
                No an etch primer is something different. Possibly better in fact than zinc chromate for priming aluminum etc. It is very often a two pack and acid based product which may contain zinc tetroxychromate but can equally be chromate free.
                • #9
                  Are those the new fangled gold coated clamps?
                  Steve.
                  • #10
                    Thanks for the help guys. I didn't see anything at Napa but I did find Duplicolor self etching primer at Autozone for $5.99 a can. It is has the same green color as zinc chromate. Hope this stuff works.
                    • #11
                      Rustoleum has it only its called Self Etching Primer and can be purchased at Home Depot for $5.49/can
                      • #12
                        That's what I use - works fine.
                        • #13
                          Damn and to think just last season I payed $15 for the damn zinc chromate, I think im gonna strip the whole thing and use the cheaper stuff now and repaint... Should be cheaper right
                          Edit: how did I not notice this thread is over 3 years old? Hehe oh well...
                          • #14
                            Careful here guys, read the labels:
                            Dupli-color, and other Zinc primers are now Zinc Oxide, not Zinc Chromate. To get Zinc Cromate, you can got to an aircraft supply as it's used on planes.
                            sigpicLets go fishing!
                            1932 Muncie Neptune 1-1/2
                            1947 Mercury KE-4 Rocket 7.5
                            1948 Evinrude Lightfour 9.7
                            1949 Evinrude Zephyr 5.4
                            1954 Johnson CD-11 SeaHorse 5-1/2
                            1975 Johnson 9.9 w/ 15 Evinrude power head and carb.
                            • #15
                              i just bought a can of duplicolor primer from canadian tire (a week ago, to restore a cowl for a 56 johnson).......its clearly labeled as "zinc chromate primer".
                              many men fish for years without ever knowing its not about catching one.
