Re: 1993 johnson 48 hp
Did you get the main jets?
Sounds like not.
They are inside the drain for the float bowl and you need a really skinny straight screw driver to get them out.
Use a stripped stranded copper wire, nothing harder than the jet, and run it through a couple times, should do the trick.
Did the same thing last year, replaced my entire ignition system and all it was was dirty jets.
Try that and repost results.
