Just changed water pump and filled gearcase on '74 Evinrude 115 hp that has sat for years everything seems ok except for small leak @ lower bearing set screw (small allen screw in right side center of gearcase). I turned screw in about a half inch but it never tightened and still leaks, I'm afraid to keep turning it in. Should I keep turning or apply sealant? Any help?
